SHARK1972
10 Ottobre 2016
281
109
FIRENZE
Rieccomi, oggi ho fatto un piccolo upgrade, si fa per dire......
Montato roval traverse 38 carbon e i dischi hope......anche dietro.
7_onHpprw0auQHx1fAbMbNkcRhQFt52Z6zUdUPQQFY7fpU5YsCDAJMZ0tOpoB8eapQH2vJ1a7Gdu39W3Ff1t71H7lVd6IsUCHoCOPvZsTK2TU2bpOPEUbTZysvEOtGtbjHa8kWcYGY-Vwd2OIJUEvyRkKZ5yn2chbivlLkGj3ZCI4fGs_qON6Bk2Jkeas4ZTMI482I4NahRg42YQvQ5HszmODu8ob2NXH31wO8qO4cwOGsueW4-bQ0KYDz5OuvS2R__RzTTOk3ZvkJ3KqBKEGKiXc3yfwr6ff1oisJaz_Qy528w64TIc4NgRnCIT5lOhVTe4-OTNzoPynhCws3zxwEO_RHrF0T_rVuvKRBkpAhYJcjYr6Vs3-NTkZ3W8MONX9Q6xzMd0iV3ix-viIxAJbjmrQ8N_vsoMBvVeyeNkVXF6vpfzTxq9TIKECKmk0QAagYbD7v5n7L3Su9xhxdFz3lO58d9vmUYomx4mvKm1gom8NpVUBW4c4ALZGXywUGNa92koA5nd6fMq-Y1lHvglij-ymOgfWLPVcVPbx3-JEnTi2DPdClGMge2yWPmfHtq2YC4sW7EQrVdlardc4HOmLwaCSuar4E2WpiKgQrOIL_Lt4iABKNMm=w960-h540-no
X5d21aFfnKOWXlCZ807TwbFUr5PdwAtxf4_A2Cy_ojghZnc9XUTxbj1mL1CO_cXr0kKWdS8CHQ8QTzQxMOLUc4-2tjsJY097B-3EEWXv4SxMsg-K7DFxNXqXEIHtkYam2uPLCc96olOx2TufhjChcYigIdCv1IFui-In4XWn-9jYUwJKmaEL6XW7YmfnhB646S4qA6OMVC-o8SQ1bpaSBQgaJiAS13Wk6BWTPfBcCtxaapBgqXZDtaMltFZnl0A9BEq2azuyW6N1YSzxVcRj_9qlUR-Jc89MZX3CbjLUN3MkH_XZuEURiNfb8_MXu4vxlD3J07ZmiVhpTHqvb6Exhpdp3FMaX4NVEbgiW1Tru-TwCau1G3XkRk3XMq21B32a30eoqxl3rKtOlFXxfyInz4DIm-b5MfQ6nX9LV2I35bkwae246DDq4oR_yA-fY7KomaFtVd3tsFFYHCGBSiP4IdEUBBDkWtx36xwf3sw9wmLuHPSaLUVEKSzlpF27bNXYU9hp0ShYcQl9qTsBUn-Yc8mwGbPj1eTVhzC6nJ62xoo1hUmn8_T3rQT_csmoM9imv47DbZVNqGenB7vuuy1_K1H-mc_tn8O9kPNLjP9AaV76yywi=w960-h540-no
RZDzXmTpFa4r1iFeYcLA3vXMdyhuXGTRuSgaaqCqjF-xMl8KrHxksKMW_rL8e5SpOyGQF6JJO-HtICZeiJmuOL_ubxaskvhb2aRZ82EK7zeSI1asQW9ugiwEfBsmPMOzIlw8_-RknBGfTudrxz-Yp7dnXpdmrZK6GPWYvWN8aWp6DZ6gYbP9TKHP1c7zPWb_TGN9WXl59L-wyOJZCINZnviwm3kYDUyvIkgJ-mSphBPx2K1CuUyry7pbKwz3CKE_oDoLwYr1E16dbbMFJhbVdBta-DJTslPX8gIx84VF3QS2ikYhRZd9u8ZoAdqIlt3XRHKgweEp6GsCqprVBdaQj0RqeBAkQnyfThlmhNdGXyskAqNbsXBzc9_WWw29S5vsRL_mY6pngucLSE_FMvO9rsDfQDsnli83giuDsjPFgQ3WcttXt-rlyxw-Fu0SCV5WJHAKIvwpvF6dSai1Co2sJRanMF3Shwi939RNXUOU7hTFVOMgjcR4VbznDtO2FIA52IfSlX0cIs9AuB8JkEr-OZzPxgbRPrh-UKIcAfghpwgueHOvRQ3SCqWu7wi0lX-U8jN23qh9csRSGZm0Oppp82nm9M4M_5L847sy1Q0TOsohC3Bx=w960-h540-no
OWmHEEBVFEm2K7rYjyzh2TXhFAQ8ovKOuLPqSLY-A2ld4CXbTDq6KIdlP2T5_3OFkyeY_CuvB1m-1iojJ8MTbTh6-MFz2cTRzq6eI3CTyOdEh4iaIAllxYjEifra9fm241aI3fOWg-TSWUf4TEMTtHV33lLmvFz-fNvDdt0Dy99LdIYo8FrZtwIeNVJqBlSY227dk6-eCgits9hMNawTdktYpQo6DdDeNyYY-VLE1vohiyz7SsslED4UB0soGAC7eHBNHNLDlalHb2ZhK_fO1TQru9xnnnwxrLCU0D7hIjBde874pppaJrp-Kf8Ovc0WqfaylCTrMp-8sAYPcnth0xv_SMzr0eoe6L3t_QFno8Iteazge-PxENmFXt7ihQeyIYoN_AtjoSbC0t6IZBD3fELgs7DJReYVgE-lHkcXgosBBFlycaz4-nCzbGs0-UBxP7h-9Ah8XQr6r8d9hN0F8ucA9oGHQgsMw3E2Z8c3X3tB0yGCqcdL_PHtoRI2kbWnbyt9L_D21F2HAPyNqxxLLrMjxOtAtkW_7HKDhsO65H4znuxZZhebUoQ3vRZvAb8-f34jmKoUMG1Klsmv4ojNFGA1WXqQl_pIfRhxU66ulRKQbQzU=w960-h540-no
Manca l'adesivo 38 perchè pensavo ci fosse scritto SL
D
Deleted member 781
Guest
Nella sezione motori c'è il PDF del motore brose, prova a dare un occhio [emoji6]
il capo
15 Gennaio 2017
118
27
Repubblica Salentina
Venge Vias - Cervelo R5 - Epic torch - Fatboy - Salsa Bucksaw
Scusa, ma quante pagine dati ti servono per andare in bici???
Dipende dalla bici e dall utilizzo. Per esempio quelle con cui faccio le gare (granfondo, sia bdc che mtb) hanno più pagine, in una con pochi campi (2/3) ci metto solo fc e cadenza, in un altra i valori relativi alla quota (pendenza, vam, quota ecc), poi ne ho sempre una che riassume un po' di valori, tipo fc media e cadenza media, che mi servono per capire come sto andando, se rischio un fuorigiri ecc.
Con la turbo levo potrebbero bastarmi un paio di pagine. Conta che tendo a mettere pochi campi perché se troppo piccoli non li vedo bene
tango
427
Reggio emilia
pivot shuttle am
@il capo,
Si hai capito bene, le pagine scorrono solo in un senso verso sinistra.Questo vale anche per il 1000. Io ho solo 2 pagine dati, cosi non devo sfogliare troppo.
scusate , io ho garmin 820 ed anche il coman do remoto in questione , con il comando pero riesco a comandare solo l'assistenza , azionando invece il terzo pulsantino con le righine orizzontali non succede niente..... il negoziante al momento dell' acquisto mi disse che serviva per accendere le luci prodotte da garmin????
runcaa59
3 Novembre 2016
58
Ticino
Turbo Levo
Penso che il comando remoto non é stato installato come sensore sull 820. Per aggiungerlo devi andare su sensori, aggiungi sensore remoto, tenere premuto le due frecce assieme fino a che il led lampeggia, e confermare.Il comando remoto puó funzionare anche senza Garmin, solo con la Levo.
Reactions: tango
