Allora ho deciso per l'acquisto del motore TSDZ2 ora avrei bisogno del vostro aiuto per la scelta della batteria, sono indeciso su questa a 288 € su Aliexpress:
Battery Model
3620
Voltage
36V
Capacity:
20AH
Type:
3.7v 3C 18650 cell
Source Resistance
40
Charge
Way of charge
CC/CV
Standard charge Current
2A
Max charge current
5A
Charge Cut-off Voltage
42.0V
CellOvercharge protection Voltage
4.2V/CELL
Discharge
Continouns Discharge Current
30Amp
Peak Discharge Current
100Amp
Cell Overdischarge Voltage
2.8V/cell
Discharge Cut-off Voltage
28.0V
Cycle Life
1000 times
Safety test
No firs ,No explosion
Overcharge Safety Test
Crush Safety test
Needling safety test
130 C high Temperature safety test
Weight
5.0kg
Bag Size
50*83*268*368*418MM
Fit moto power
Less 1080w
Working Temperature
0C—45C
-20-C—65C
Retention of charge
>95%
Certificate
CE,UL,ROSH,UN38.3,MSDS
Application
E-bike,E-motorcycle,E-scooter
Warranty
One year
Oppure questa a 285 $ su pswpower:
Electric Bicycle Battery 36V 17.4Ah Hairon li ion Battery with NCR18650PF cells for Bafang 8fun 36V 500W E-bike Motor with charger
1. Rated capacity: 17.4AH
2. Voltage: 36V
3. Charging Voltage: 42V
4. Discharge cutoff voltage: 27.5V
5. 6P10S Li-ion 2.9Ah Panasonic NCR18650PF 18650 cells
6. Continuous discharge current: 25A
7. Pulse/Max discharge current 50A
8. Max charging current : 5A
9. Charging temperature: 0~45
10. Dischargeing temperature: -20~55
11.Operating voltage:28V~42V
12. Diamesion:90*92*361mm
13.Weight of battery pack About kg
Note: Please turn on the power switch when you charging this battery pack.
90W Lithium Ion Charger Specification
Input Voltage: 100-240V
Output Voltage: 42V (for 10 series Lithium Ion battery use)
Output Current: 2A
Charging Mode: CC-CV
Intelligent Charger
Super Powerful Charger 2A
Cosa dite sono buone batterie per il TSDZ2 da 350w?
