Scusate ma anch'io dovrei prendere una emtb con quelle caratteristiche.
Ho trovato nuova una Cube Stereo Hybrid 140 Race 500 27.5 mod.2019 con queste caratteristiche :
(Telaio: Aluminium Superlite, Gravity Casting, Triple Butted, Efficient Trail Control 4-Link, Agile Trail Geometry, Boost 148, Tuned Drive Position, AXH, Full Integrated Battery Colore: iridium n blue Misura disponibile: 27,5 tg 18" Forcella: Fox 34 Rhythm, 2-Position Sweep-Adjust GRIP Damper, 15x110mm, E-Bike Optimized, 140mm Ammortizzatore: Fox Float DPS EVOL, 190x50mm, Open/Medium/Firm Mode Viteria ammortizzatore Top: 30x8mm, Bottom: 30x8mm serie sterzo FSA 1.5E ZS, Top Zero-Stack 1 1/8" (OD 44mm), Bottom Zero-Stack 1 1/2" (OD 56mm) Attacco manubrio Newmen Evolution 318.4, 31.8mm Manubrio: Newmen Evolution 318.20, 760mm Manopole: CUBE Race Grip 31mm, 1-Clamp Cambio: Sram NX Eagle(TM), 12-Speed Comando cambio: Sram NX Eagle(TM) Trigger, Single Click Freni Magura MT Trail Custom, Hydr. Disc Brake (203/180) Guarnitura: FSA CK-745, 16T, 170mm Pacco pignoni: Sram PG-1230 Eagle(TM), 11-50T Catena: Sram NX Eagle(TM) Cerchi: CUBE EX30, 32H, Disc, Tubeless Ready Mozzo anteriore: Shimano HB-MT400-B, 15QR, Boost, Centerlock mozzo posteriore: Shimano FH-MT400-B, 12mm, Boost, Centerlock Gomme: Schwalbe Nobby Nic 2.60, Addix Speedgrip, APEX, Tubeless Easy Pedali: CUBE PP MTB Sella: Natrual Fit Active Race Reggisella CUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mm (16": 370x100mm, 18": 420x125mm, 20", 22": 480x150mm) Bloccaggio sella: CUBE Screwlock, 34.9mm Motore: Bosch Drive Unit Performance CX (75Nm) Batteria: Bosch PowerTube 500 Caricatore: Bosch 2A)
A 3k. Me la consigliate?
Grazie.
Grazie.
